The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering.
283 Questions View all
dosn't always charge
Most times when i plug my iphone into my apple wall charger it registers the charge with no problem. But, sometimes it will connect and charge for a short length of time, then will randomly loose it's connection and won't charge. I try to reconnect all connections, and try different outlets ... with no luck. The only way that it will then charge is while plugged into the computer. Then when I try to plug it into the wall charger, it works no problem again. This happens randomly. What is causing this? How can i fix it?
Add a comment
1 Answer
Chosen Solution
Sounds like you need a new wall charger, buy one here.
Edit: looks like its out-of-stock ATM, either check back later or look for one elsewhere.
Add a comment
Add your answer
Pat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 964
