Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Questions View all
SAMSUNG 850 EVO 2.5" 2 TB drive as my 2nd. internal drive
Hi
I am trying to add a SSD drive to my mid-2011 (iMac 12.2). Is the following drive compatible?
SAMSUNG 850 EVO 2.5" 2 TB SATA III 3-D Vertical Internal Solid State Drive (SSD) MZ-75E2T0B/AM
http://www.newegg.com/Product/Product.as...
Add a comment
1 Answer
Chosen Solution
If you are adding the drive just follow this IFIXIT guide: Installing iMac Intel 27" EMC 2429 Dual Hard Drive Kit
You will need a cable set and the tools to open your system. Here's the kit IFIXIT offers: iMac Intel 27" Mid 2011 Dual Hard Drive Kit
As for the Samsung SSD we have mostly them in our iMac's with great success.
If you are thinking of switching out your current HD for the SSD there you will need a special adapter cable to replace the needed thermal sensor which is in the HD and not in the SSD. You'll also need an adapter frame as your current drive is a 3.5" and the SSD drive is 2.5".
I strongly recommend adding the SSD drive Vs swapping out the HD.
iMac Intel 27" (Mid 2011) Dual Hard Drive Kit Image
Product
$27.99
Score 2
Add a comment
Add your answer
Hal Lavender will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 95
