Why my toyota tacoma audio system losses saved radio channels
Saved channels in the radio system losed when i turn of the car
Hi,
There are two power wires to your audio system. One is from the ignition to run the audio. The other is to maintain the 'memory'.
Here is an image that shows the wiring for a 1998 Tacoma, (you do not state your model year so hopefully it may be the same).
As you can see there are two (2) fuses feeding the radio. The Radio fuse and the Dome fuse. Check that both are OK. If so then perhaps there is a problem with either the wiring or the connections to the radio.
Hopefully this is of some help.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 174
