To fix iCloud lock
Where can I buy hdd for iPad Air 2
By replacing the hdd I can eliminate
The iCloud lock
Thank you all, josef
The iCloud lock
@berjo the iPad does not have a HDD. All files and system information are stored on IC's. The only way to unlock it is through Apple with proper prove of ownership. A new logic board that is not iCloud lock will of course work as well.
The iCloud data is stored on Apple's servers. It will continue to come up no matter how many times you restore it. There is no effective way to remove it sadly. You must have the iCloud login or request the prior owner log into their iCloud account and remove the device from their account. Then you can DFU restore it.
Hope that helps.
Holger
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,090
2 Comments
Have you tried the System Restore using the ITunes and the unit connected to a computer?
by Brian Reeder
PS: make sure the computer doesn't have the ICloud software installed.
by Brian Reeder
