Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Question Closed
Replaced HD, system does not recognize new drive
My Mac was crashing so I bought a new Western Digitial 7200 RPM drive and I wanted to install it clean.
I have a 10.6 Disc and when I boot to it I don't see any option for my hard drive.
I thought it was the cable but I put the old Toshiba drive in and it sees it fine.
Could it be the cable or the drive is not usable. Also I did format the western digital drive on another Mac to OS X Journaled Extended with GUID table.
After that I stil did not see it in the disk utility from the disc or when trying to install the OS.
Also I did use a usb sata cable and connected it to my western digital drive and it did see the drive in the 10.6 cd's disk utility But once I use the internal cable it did not see the western digital drive.
Thanks in advance.
5 Comments
Can you give us the exact model of WD HD you have.
by
Western Digital WD3200BEKX
by
Here's the spec sheet for your drive: WD3200BEKX
by
New 3.0gb drive is showing. However when I try to install 10.11 from usb drive it starts the install then fails with the error "AN error has occured while preparing the installation. Try running the installation again.'
I already tried and fixed the time and date on the mac through the terminal.
I noticed I can't erase the drive I tried it gives an error.
by
Add a comment
1 Answer
Chosen Solution
Sadly the drive you bought won't work with your system. The drive is too fast for your system.
Your systems HD SATA port is SATA II (3.0 Gb/s) while the drive you bought is a fixed SATA III (6.0 Gb/s) drive.
You'll need to return it and get a different drive one that is SATA II (3.0 Gb/s) or one that has auto SATA speed sense.
Score 2
16 Comments:
Thanks for the info I'll give it a shot and let you guys know. Thanks again for your help!
by
You may want to also check your systems firmware. Follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers make sure you have whats listed or newer.
by
Hey you we're right about the drive! However now when I try to install I see the drive but I get a new error.
by
OK what's the error?
by
I tried 10.11 From a bootable USB drive.
If I use 10.6 or 10.7 disc it doesn't detect the drive.
Before I used the drive I plugged it into another Mac running 10.11 and formated the drive to OS X Extended Journaled. It put some small partition on the drive and when I put the 10.6 disc in it didn't see anything. When I tried 10.7 it only saw the small partion that was installed when I reform matted the drive.
by
Show 11 more comments
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 139
