Where can I get a battery for it
where can I get a new battery from
Hi,
There's not much information about regarding your tablet's battery except that it has 2400mAH capacity.
Here are some links which show firstly how to open a generic Chinese manufactured tablet and secondly how to identify the Voltage, Capacity and dimensions of the battery as well as how to replace it.
Once you have this information you should be able to search for a replacement battery using the information that you have found. The actual brand name of the battery will probably be irrelevant, so long as you get the other parameters to match you should be OK, i.e Voltage, capacity and dimensions.
e.g. for the battery shown in the 2nd video you would search for 3.7V 5000mAH 4297108 battery.
Here is a video that shows how to open a tablet. You only have to view it as far as getting the tablet completely open as it deals with a different problem.
https://www.youtube.com/watch?v=mb8caOVj...
Here is a link that shows how to identify and replace the battery.
https://www.youtube.com/watch?v=TZeFFGKy....
Note: These videos are only here as examples to show you how to get at the battery so as to assist you to find the information that you need. I do not know if what they show will be exactly the same for your tablet.
Hopefully it is of some help.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 81
