Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 разлила водку (poured water)
после этого положила в рис,потом вытащила какое то время работал,и потом окончательно не включается не на зарядку не реагирует,носила в сервис почистили но толком ничего не сказали,что можно сделать?
Google Translation
iPhone 6 poured water
then put into the rice, and then pulled out some time to work, and then finally switched not to charge is not responding, the service carried in cleaned but did not really say anything that can be done?
Score 1
Add a comment
1 Answer
Most Helpful Answer
@sonia222 do not use any rice. It does not work!
First thing to do is to no longer try to start or charge your iPhone. Remove the battery, and disassemble is right down to the logic board . You must remove the EMI shields for a proper cleaning. Clean everything with isopropyl alcohol (90%+) and a soft brush, including all connectors and cable ends. Use this guide to see how to clean it. It was written for a 3G but all the points are pertinent to your phone as well. Check for any burned or missing components. A professional ultrasonic cleaning would of course be best. You may have to repeat this step a couple of times. Once it is cleaned, reassemble it and replace the battery, then reevaluate for any real damage. Water damage is the hardest to diagnose and thus very difficult to repair. Virtually any part may have failed. Until properly cleaned anything will only be a guess, and the longer you wait the more corroded it will get.
Google Translation:
@sonia222 делать 'не' использовать любой рис. Это не работает!
Первое, что нужно сделать, это больше не пытаться начать или зарядить свой iPhone. Извлеките батарею, и разбирать это вплоть до the logic board. Вы должны удалить экраны EMI для надлежащей очистки. Гладко все изопропиловым спиртом (90% +) и мягкой щеткой, включая все разъемы и кабельные концы. Используйте this guide, чтобы увидеть, как очистить его. Она была написана для 3G, но все точки имеют отношение к вашему телефону, а также. Проверьте, нет ли сгоревших или недостающих компонентов. Профессиональный ультразвуковой очистки, конечно, будет лучше всего. Вы, возможно, придется повторить этот шаг несколько раз. После того, как она очищается, собрать его и 'заменить батарею' , а затем переосмыслить для любого реального ущерба. Вода ущерб труднее всего диагностировать и, таким образом, очень трудно исправить. Практически любая часть может потерпеть неудачу. Пока очищено ничего не будет только предположение, и чем дольше вы ждете, тем более коррозией она получит.
iPhone Image
Guide
Repairing iPhone Liquid Damage
Difficulty:
Difficult
1 - 2 hours
iPhone 6 Logic Board Image
Guide
iPhone 6 Logic Board Replacement
Difficulty:
Moderate
30 minutes - 2 hours
Score 4
Add a comment
Add your answer
Kerry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 290
