The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
498 Questions View all
Diagnostic mode for Kenmore Elite He3t model 110 42926 110 washer
This Kenmore 110 42926 220 washer look like it should work. But when you press the start button nothing happens, yet the leds come on solid ( not flashing ). The door doesn't lock , ETC. I tried to reset by pulling the AC off for twenty minutes several times. Then unplug /plug AC, shut the door and hold both the Start and cancel in for an count of twenty. I tried to enter the diagnostic mode but it wouldn't come on . I tried several methods suggested by Online and U-TUBE. Is there a different way to enter the diagnostic then the others or does this mean the CC module isn't working right ?
Add a comment
Most Helpful Answer
I believe this is very similar to the model I have. Here is what I did to run a diagnostic.
  • With the washer empty, close the door.
  • Push “control/on” or “Start”
  • Select “Drain/Spin”
  • Select “No Spin” by pressing SPIN SPEED touchpad.
  • Push “PREWASH” option four times within 5 seconds. (If there is no PREWASH option, press RINSE HOLD 4 times in 5 seconds.)
  • C:00 should light up and begin the diagnostic.
Score 2
Add a comment
Tap drain/spin button. Tap spin speed button until it gets to “ no spin”. Tap the “prewash” button 4 times. Diagnosis will start.
2 Comments:
Im trying to reset my kenmore elite machine.when i plug it in it just keeps beeping and lights flashing and doesnt respond?
by
@gypsyqueen5150
What is the model number of your washer?
by
Add a comment
Hold down any button ,besides start and stop for 3 sec, off 3 sec, on 3 sec off 3 sec until all lights come on and panel reads 88
Add a comment
Add your answer
Richard Brickell will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 66
Past 30 Days: 255
All Time: 26,190
