Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
Can I change just the home button cover?
I'm about to undertake the black to white iPhone 4 conversion. I wanted to know if, when changing the home button from black to white, do I need an entire home-button assembly with the cable? Or, can I just change the colored-plastic portion of the button?
Thanks
Score -1
Add a comment
Chosen Solution
This ended up being a piece of cake. The Home button is obviously VERY important to the operation of the iPhone so I didn't want to break this delicate flex cable part on my original button. I ended up ordering a new black button with flex cable attached and used an Xacto knife to carefully go around the edge of the silver button that was glued to the back side of the button. It's just held on with a little adhesive but by carefully going around it with the knife, it lifted easily and went right on the new white Home button. You can easily do this with the original Home button but I just played it safe.
Add a comment
The cable is lightly glued to the back of the home button, simply peel it off and attach it to your new button
Add a comment
Add your answer
Barry Harari will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,412
