power switch is in protection mode
How do I fix this problem checked fuses and still not releasing
Hi,
Have you tried the reset procedure as per the troubleshooting section in the User Guide?
"Remove the power cord from the wall outlet. Disconnect all speaker cables and input sources and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and set the volume to maximum. If the AV receiver stays on, then set the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources.
If the AV receiver turns off when you set the volume to maximum, disconnect the power cord."
Also are you aware of the information contained in the following link? Click on the link in the page, Loss of Audio/Network Connection Customer Care Program for USA and Canada Customers to find out if your unit was affected.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,089
