Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Rear camera doesn't work even after replacement
Hi everyone
I have iPhone 5 that the rear camera doesn't work.
I have restore the phone to factory settings and replaced the rear camera and still no luck.
The camera is just black. Front camera working.
I disconnect the battery and connect it again.
Any more suggestions please help
Thanks
Score 1
2 Comments
I have the same issue with an iPhone 5s.
by
Did you try to factory reset the phone with iTunes?
by
Add a comment
Chosen Solution
For example it's not the first time that I see this component u13 fail. If you can measure the rear camera tension on the line before this component but not after it you can remove it and run a jumper to restore the tension that allows the rear camera to work. It could also be one of the many filters or capacitors that are on the rear camera connector lines, they are a lot. It's not easy to find the problem and it's also more difficult to fix it without a microscope and some experience in microsoldering.
2 Comments:
thank you very much for the support.
by
you're welcome
by
Add a comment
Take it to Apple ask them for a complete fresh install of iOS not just a restore
1 Comment:
Any other suggestions different than taking it to Apple?
by
Add a comment
There are several component on the board that could have failed so there is not the right communication between the logic board and the rear camera. It is a microsoldering work, without the right equipment and skills you can't do anything more than that, I'm sorry. You could try another camera but it almost impossible that the two you have now are both faulty.
1 Comment:
Hi James can you send me example of the components that may fail? Thank you
by
Add a comment
Add your answer
Mimi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 11
All Time: 166
