Guides and support for various television (TV) brands and styles.
9064 Questions View all
TV picture suddenly distorted
The picture on our LG V5500 LED TV all of a sudden has difficulty with certain colors. Some images seen clear but others are very funky. Dark colors in particular. Green splotches appear over darker colors with vertical lines appearing in the splotches.
Update (03/30/2016)
this is a picture of the current issue.
Add a comment
Most Helpful Answer
Steve Pearson,
If your television has image distortion issues, see the Insignia NS-24ER310NA17 Has Image Distortion problem page for possible causes and solutions.
This is possibly a LED driver board issue (around $40USD), a bad main board, or a bad LCD (unlikely) I'd go with a new driver board. This one should work
Score 2
1 Comment:
Thank you! I'll give it a try...
by
Add a comment
I had a plasma (as opposed to a LCD) and it did this and it was the logic board dying. I would suspect something similar is happening with yours. The repair parts alone were more expensive than a new TV, however your case may be different. A quick google with your exact model # and "logic board" may get you the answers you need.
Add a comment
Add your answer
Steve Pearson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 29
All Time: 2,653
