The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3638 Questions View all
Battery % doesn't change. Need help to identify Components!
I have a very strange fault with a couple of iPhones. I regularly replace the rear housing of iPhones, I am very careful with the replacement of screws (correct screws in correct positions and not tightened excessively). I have successfully completed this over 50 times and consider myself fairly competent in doing so.
However, I have come across something which is very bizarre and has happened on three separate occasions now. Once I turn the iPhone on to test it the phone will blue screen and restart itself two or three times at random. Once this has happened the phone will function perfectly except for the battery % display will not change. Obviously this causes the user to not be able to track when it needs charging. The phone will run out of battery and the process will happen again.
It must be something I am doing to the phone, I am not overly fussed on finding a fix. Just a reason why this is occurring and how I can prevent it happening again in the future!.
Thanks in advance,
Update (03/31/2016)
I have done some more research and believe that the issue may be an "FL 11 capacitor" could anyone confirm this and give me some info about what it does exactly and where I can source one to try and fix the issue?
Update (04/01/2016)
So I have had a look at the logic Board under a microscope and have found that some capacitors have been knocked off when removing the battery. I think the one on the far left is a "FL 11 inductor" but I am not sure what the other two are. Could someone tell me what they are?
Good Logic Board :
Damaged Logic Board :
Comments:
Hi, I had not seen that. Have had a look over and has confirmed my theory that I may have accidentally damaged the"FL11 is a 120ohm 210mA inductor". If someone could confirm this it would be ideal.
by
Add a comment
1 Answer
Chosen Solution
Chris from right to left:
FL11 is a 120ohm 210mA inductor in a 1005 package
C279 is a 56pf 16V 5% capacitor in a 1005 package
C23 is a 56pf 16V 5% capacitor in a 1005 package as well
Score 4
Comments:
Hi I'm Felipe Zuluaga and I go to Tray to speak in english... i have exactly too problem but i have a the boar that change the components, trying to change I lost C23 and FL11, can remplace the component this with other capacitor an inductor?
by
Felipe Zuluaga why not replace it with the right components? You do want to change a capcitor for a capacitor and inductor for inductor. You are not thinking about changing a capacitor for an inductor?
by
The capacitor does the opposite of what an inductor does. If you do that the battery circuit will not work.
by
I go to change the components, but I have a problem try to soldering. What kind should I use Soldering, wire or liquid? And what kind of point of the soldering iron?
by
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 495
