Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Screen works perfect, but no backlight?
hi everyone I had a light spill on my macbook pro and it barely touched the logic board. It works flawless on external, but only problem is that the backlight is gone? i can see screen working with a light behind display. How do i fix this? Is the backlight controlled by the LVDS cable or what? the screen looks perfect just no backlight.... please help me
Score -1
Add a comment
Chosen Solution
It might be the inverter. LCD inverters take the incoming DC power and invert it to higher-voltage AC power to the tubes to light the screen. Macbook is LED so no tubes I guess but it still has an inverter. My inverter went bad and had the same symptoms. I might be completely wrong, but thought it might be worth passing along the information. weather or not it's possible to damage this part from what happened to your machine, I don't know. I do know apple usually just goes ahead and replaces the entire screen when done under warranty for this problem.(which means it's probably pretty deep inside the display assembly I guess).
Add a comment
Sounds to me like you have a WLED driver that is bad. It is a chip soldered directly to the logic board. Also a alternative is a fuse that is located near the same component. Both these require soldering tools and a steady hand. There are many write ups on here referring to your problem.
1 Comment:
Please note there is NOT a inverter on this model.
by
Add a comment
Add your answer
kris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,081
