Laptops manufactured by Dynabook (formerly Toshiba). Toshiba has since transferred 100% ownership of the laptop business to Sharp.
1272 Questions View all
All USB ports not working for no reason
So i have a Toshiba laptop that i use regulary, and while i was using it a couple of days ago the mouse just stopped working. I started trying different things in the USB Ports, and none of them work, so i know it cant have just been that mouse. I hadnt pressed an odd key or anything since every key ive tried has done nothing to fix it. ive looked at tutorials all over youtube and none of them have worked. even taking the battery out doesnt work. Help? ☹
Add a comment
You Need to upgrade your usb drivers.
go on toshiba website and update them.
that should solve the issue
5 Comments:
check under you laptop there should be a sticker saying model number.
https://www.toshiba.eu/innovation/downlo...
by
@blanco Every time I type all the things in it just says that they cant seem to find matching info. ive looked under my pc and it doesn't say anywhere what model number it is.
by
It doesn't say what series either.
by
@blanco nevermind, done it. Thanks so much for your help! :)
by
no problem. :) glad you have solved it
by
Add a comment
start by login bios check if the usb are disabled then try to do resotre your windows to date that work fine
if nothing happen you must pull out the motherboard and do the voltage test
Add a comment
Add your answer
no. will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 107
