The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3661 Questions View all
Help me Touch ID don't work
Hi
I have replace the lightning connector (two time)
Now the Touch ID don't work
(Home button go well)
Is possible know if the ID work when the iPhone is open so i can do some test or it work only after iphone is close?
Comments:
Did you replace the home button? That would kill the touch ID.
by
Add a comment
1 Answer
Chosen Solution
if you replaced home button then that would be the reason, however you only mention changing dock twice.
you can certainly still test the Touch ID and home button when phone is open (obviously as long as its connected )
my guess is you've pinched or torn the cable and theres no going back from that. those cables are very flimsy and don't stand up to much. The more you disconnect/connect/open and close, then the weaker that cable can become and just come apart .
Score 2
Comments:
Thanks 4 the answere...
Can I try something else?
Some test?
Take off and re-plug all other connector?
by
Try a power cycle /ie home /power button thing . but I doubt it. Most likely damaged the flex it sounds like
by
Add a comment
Add your answer
Matteo Reglieri will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 80
