Help finding a replacement LCD Panel?
Hi could any one help me find a replacement LCD Panel for a Vizio M43-C1 ?
I've tried looking everywhere and haven't had any luck also if you might know
where to find a service manual I'd really appreciate it!
Thank you,
Update (03/23/2016)
Thanks for the response I took it apart and believe the maker of the lcd panel is TVP and the model number is tpt430h3-qvn01.u
I searched and couldn't find anything?
Any help would be really appreciated.
Thanks
Score 1
Add a comment
1 Answer
Chosen Solution
Hi,
Have you looked on the back of the LCD panel you have at the moment, to see if there is a part number stamped (or barcoded) on it?
If there is 'Google' just the numbers (or whatever you have found), do not mention Vizio in the search as most probably the results will focus on it rather than on the numbers. With a bit of luck you may get supplier info, as the screen is probably not made by Vizio anyway.
Update (03/24/2016)
Hi,
There are a lot of sources for the board parts for the TV when you look for tpt430h3-qvn01.u
You might wish to try contacting the people in these links, as they might know about replacement panels.
http://www.shopjimmy.com/vizio-756txfcb0...
http://www.buyqual.com/vizio-43t03-c00-t...
This is the only panel manufacturer that I can find that has TVP listed in their products, so perhaps they are the makers or perhaps not. How this helps you I'm not sure as I'm thinking that even if they were that they wouldn't supply on a one off basis.
http://www.asia-manufacturer.com/manufac...
Hopefully this will get you a bit further down the repair road.
Score 3
Add a comment
Add your answer
bob will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 2,762
