The Sony Xperia Z5 Android smartphone was released in October 2015. The Sony Xperia Z5 features 5.2 inches 1080 x 1920 pixels display and is equipped with a Qualcomm Snapdragon 810 processor alongside 3GB RAM and a 23 MP rear camera.
Sim stuck in slot
Sim card stuck in slot deep
Xperia z5
Not on the sim tray
Iv got that out
I didnt know what it was for
Score 3
1 Comment
My sim card is stuck inside Th the phone still, I can't seem to get it out, I é tried everything lol I'm not good at this kinda stuff
by
Add a comment
Most Helpful Answer
Last time this happened to me, I stabbed the sim with an exact knife and pulled out slowly. Took a try or two but worked
Score 4
1 Comment:
Brother Robert thank u soo much bro. ur comment helped me and i successfully pulled out my sim. JazakALLAH !
by
Add a comment
If the phone doesn`t have a push/pull configurations, then the sim would`ve stucked inside a tight space. To remove the micro sim, you will need a small piece of metal that can slip into the micro sim slot and then push it outside so that it would go out. Don`t try to press it forward because it will just make it harder to get out. If you don`t want to damage your phone further, simply go to the nearest Sony center which will they will do it for you for a fee of their service.
Score 3
Add a comment
Mine is stuck as well in th sim port but I've tried a needle, I've tried tapping my phone around but it's still stuck and Sony says that it isn't covered under manufacturing defect so they won't do anything. So I'm stuck with a phone that can't be used as a phone because the tray will only fit halfway in. Is there anything I can do?
Score 1
Add a comment
This thread was really useful. If you look carefully you will note the there will be some space on the side of the card, as the SD slot is wider. I have successfully used a paper clip to take the SIM card out without much trouble.
>> Push an unwinded paper clip inside on the side of the SIM card and fish it out. <<
Score 1
Add a comment
Add your answer
Kc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 12,554
