Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Questions View all
Display or Logic board failure
Hi,
My display is having these problems with a solid bar in the left side which is acting erratically from the other part of the display.
Do you think it's the display itself or the logic board or another thing?
Pictures
Score -1
Add a comment
1 Answer
Chosen Solution
I would recommend you try plugging in an external monitor to double check. But I strongly believe you have a bad display here. What likely happened you either banged the lid or you placed something heavy on it. When that happens you break the fragile electrical connections between the LCD's glass plate to the circuitry and connection to your logic board, we call this a Tab error.
Score 2
1 Comment:
It works with an external monitor. Ill try to order a new screen assembly and install it. Thank you very much :)
by
Add a comment
Add your answer
msvendsen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 151
