won't start won't spin won't run in any cycle lids stays locked
won't start all the lights turn on but won't spin on spin cycle won't fill doors stays locked have to unplug and wait to unlock lid
Tough one. First unplug it again and leave it unplugged for 10 minutes to allow a full reset.
Does it give any error codes?
Cause 1
User Control and Display Board
To determine if the user control and display board is defective, try pressing the buttons on the control panel. If some of the buttons work, but others do not work, the control and display board might need to be replaced. Additionally, if the display is not working, check the power to the user control and display board. If the user control and display board has power, but it isn’t working, replace it.
Cause 2
Timer
The timer is frequently misdiagnosed—before replacing the timer, first check all of the more commonly defective parts. To determine if the timer is defective, consult your washer’s wiring diagram and use a multimeter to test the timer for continuity.
Cause 3
Line Fuse
The line fuse blows if the washer circuits are overloaded. If the line fuse blows, the washer won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. Check for shorted out components such as the wires, motor, or drain pump. If you don’t resolve the underlying issue, the new fuse will blow too.
no codes available display works push buttons work center dial cycles through
is it filling with water? is this a new installation? Any power surges? previous repairs?
5yrs old no power surges the clothes get wet but then it gets stuck not willing to drain fully was able to drain it a little manually by putting hose on floor then it cycled for a bit then stopped with still water in it and I had problems opening it. finally got it open after trying ever option available except force.
Still has water but can't get into any cycle. Had previous filter issue wouldn't fill but resolved then about a month ago .Changed water line filter.
That's where I would start is with that line filter, pull and check it, make sure it is the correct one. But it also sounds like it has a clogged hose.
Most Frequent Causes for Washer won't drain
Cause 1
Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Parts
Cause 2
Clogged Pump or Hose
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.
Cause 3
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not drain. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
will check it tonite when I get home will let you know.thks
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 173
1 Comment
all I hear is it going clicking like a sensor switch clicking on and off for about two minutes then dead sound for every. Till time runs out then it turns off without movement in any cycle when I try and cycle it the door locks and I have to unplug It to try and open it
by steve
