Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Questions View all
Can the memory be upgraded?
Is this true for a macbook 13 inch pro late 2011? now has two x 2 GB RAM cards
1 Comment
Here's the specs for your system: MacBook Pro 13" 2.8GHz i7 (Late 2011)
by
Add a comment
1 Answer
Chosen Solution
Your system uses 1333 MHz PC3-10600 DDR3 SDRAM memory modules.
It has two slots which can support 2, 4 or 8 GB modules. This allows one to go all the way up to 16 GB of RAM (two 8 GB modules). You can also mix the sizes so as an example you can have one 2 GB and one 4 GB giving you a total of 6 GB of RAM.
You should make sure your systems firmware is up to date before altering the memory. Follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers. Make sure your system is at least at this level or newer.
Score 2
Add a comment
Add your answer
meadow140 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 86
