Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Question Closed
Wifi signal drops unless I stand right by the router!
I have a iPhone 6 and recently dropped the phone and now the wifi signal drops unless I stand within 6 foot of the wireless router. I have reset network setting, perform restart, enabled airplane mode and restarted connection. Should I change the lighting connection?
Add a comment
1 Answer
Chosen Solution
There is a flex cable that connects the wireless card to the actual antenna. I'll bet that it got disconnected in the drop.
I bet if you can get into the phone, and reseat the connections, you'll gain reception strength and range again. If it's torn or broken, it can be replaced.
The item looks like this:
http://www.ebay.com/itm/OEM-WiFi-Antenna...
Score 2
2 Comments:
I took the circuit board out and inspected the wireless card antenna and no issues were found. Everything was connected properly and no tears were noticed. Do you think that it could be the wifi antenna Product code: IF268-014-1? Thanks for you help
by
That would be the next in line yes.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 9
All Time: 1,626
