Question Closed
I need fix problem Boot Loop
Install rum rate phone galaxy star duos
But then I found out that I used CMW version less than required for installation
And got me a problem in the boot where the phone attached to the company's code does not enter the system
And I think that happened to me the problem boot Loop
I tried many ways but I did not succeed
Is there a solution may please ?
1 Comment
thank you guy
fix problem by Odin + Frimware
by
Add a comment
Chosen Solution
firmware file find sammobile.com
download letest firmware
turn off mobile press home button+volume down+power button
phone in downloading mode
download odin tool
select file
connect phone in pc
then start
Score 2
2 Comments:
thank you for help
i fix problem :)
by
Hello, my Samsung galaxy star is stuck on the logo. I tried the home button, off button, home button method and everything I could find to reset it, etc but every time it goes back to Samsung logo, I don’t know what to do.
by
Add a comment
Most Helpful Answer
Disclaimer: You will lose all data in your internal storage on the phone if you follow the steps below.
Steps to Factory Reset most (if not all) Samsung phones:
  1. Turn phone off by taking battery out for 30 seconds or force turning it off (if you don't have a user removable battery) via holding power button and volume down button.
  2. After that Boot your device into Recovery Mode. You can do this by holding the Volume Up + Home + Power keys. When the Samsung Logo pops up, stop holding the power button but keep holding the rest.
  3. Once your android device is in Recovery Mode, Go to the “wipe cache partition” option and select it.
  4. After that go back to the recovery main menu and reboot the device by “reboot system now” option.
  5. If the device again stuck on Android Boot Loop pull out the battery again or power off by other method specified above and follow the steps above again. This time also “wipe data/factory reset” and then reboot device.
Now your device should come out of the Android Boot Loop and at the first time the device will take some time to reboot.
If these steps still don't work then you may need to restore the software on your phone via Samsung Kies. If I can remember you do it via Tools > Firmware upgrade and initialization. This will prompt you to enter the model number and the serial number of the phone which is usually at the back of the phone or in the battery compartment.
Score 3
1 Comment:
thank you for help
i fix problem :)
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 6,009
