Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1234 Questions View all
White squares and black background on display.
My iphone 5c have only white squares and black background. Absolutely no image. What can i do with it, reconnect lcd and battery cable or this problem of processor ?
Sorry for my bad english!
3 Comments
I cant find any information about this problem.
by
Can we do anything if connector LCD on the logic board was damaged.
by
Depends on the damage but the only proper repair is to replace the connector by microsoldering.
by
Add a comment
Chosen Solution
@belvar could be a bad replacement or badly seated connector. Try the previous screen and see if that still display's what it did before. right now I would suggest that you double check your work. the connectors on the 5C seem to be poorly constructed and it is very easy to bend the contacts out of shape. This is the digitizer connector after a few failed proper alignments during replacement. One reason to be mindful during the repair
As you can see the connector lacks metal ends and this is what makes it a weak connector. It is easily possible to damage the connector by mis-aligning the digitizer connector
So again, double check your work and take a close look at the connectors on the board and the cable ends. also, take a look at this question and the answers squares on the screen after battery replacement
Score 4
7 Comments:
i didnt change screen and battery, I will try to de- and reconnect the cables. Thank for help!
by
Do not forget to clean the connectors with isopropyl alcohol and a soft brush
by
After 4 days :
Display dont on. When i connect it to charge - dont on, dont charge and every 3 sec he make "usb sound" and heat back. What it can be? Maybe U2 tristar?
by
Try a new battery. If it comes on than it could be the U2 IC. USB sound and dark screen is usually caused by the phone not recognizing the display.
by
one more thing- it connect only by one sight of lighting cable.
by
Show 2 more comments
Add a comment
I had the same problem as you, albeit with a different pattern of boxes. I fixed it by reseating the video cable, the problem went away.
Follow this guide to step 12, then reverse:
iPhone 5c Screen Replacement
This post was edited for clarity.
Score 1
Add a comment
Add your answer
Furman Vladimir will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 2,931
