Keeps restarting after screen replacment
I replaced cracked screen on my T83 TELSTRA DAVE 4G and the screen works, it just keeps restarting itself, loads up with the android man then restarts itself constantly
"Hi, Wondering if the new screen - is it OEM (original equipment manufacturer) i.e. same maker/same part number/serial number (if any) on back of screen or a 'compatible' part? Either way I think that you have proved it to be the problem If OEM it may be faulty, if 'compatible generic make' it may not be compatible. Go for a return as faulty or not compatible with this model"
by jayeff
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 113
11 Comments
hi, Have you tried a hard reset?
by jayeff
Hey there yep power button plus up/down buttons doesnt seem to work
by wisemonk
Hi, Sorry if i'm being a bit pedantic. Did you press and hold the Vol+ button before you pressed the power button, (then holding them together)? Also did you try removing the battery for 1-2 minutes, reinstalling it and then trying a reset?
by jayeff
I tried pushing all 3 at once, once i sometimes do that the red light just stays on
by wisemonk
Hi, What happens if it is 'off' and you just connect the charger?
by jayeff
Show 6 more comments
