Why wont my car run
after my car warms up you cant give it gas or it boggs right out
Without more info we're only guessing .So lets guess. Could be a fuel issue like a plugged filter or a bad fuel pump . could be a dirty air filter of a bad O2 sensor . It could be a plugged catalytic converter. More info is needed to properly diagnose your problem . Do you have a service engine light and if so what code is it throwing . Are there any idiot lights on like the oil or temp light . Is the engine oil brown like chocolate milk or black . Is you coolant level up or is it low.
Sounds like a head gasket, your losing compression and that's why when you give it gas it bogs out, does it feel like it's shaking at all?
Check the check engine light could be a lot of things. Check fuel pressure, and spark but also check tps sensor, and especially the map sensor as these control air/fuel mixture.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 94
