Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
351 Questions View all
Do I need to replace my fpc connector?
I'm in the process of replacing my ipad's digitizer and when I was testing the new digitizer, the new screen wouldn't track movement. The home button works fine but that's about it I'm not sure if it's a defective screen or what. I looked online a little and saw some people talk about needing to replace the fpc connector, so I took a look at it but I'm not sure if that's the problem or not.
http://postimg.org/image/5x2hjd6qp/
Should I replace the fpc connector or should I get a new digitizer?
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
RuiXu Tsai your image is not very clear but the actual connector looks okay. Now we cannot see the components on the board which may be an issue. Since the replacement of the connector will require some pretty good soldering skills and some decent tools etc. I'd suggest that you start off with the replacement of the digitizer. Start with the easier things first and work your way into the complicated area.
Score 2
Add a comment
Add your answer
RuiXu Tsai will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 130
