A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
213 Questions View all
Question Closed
Time display dark and washer won't fill
I moved recently. the movers did not drain the washer. The water valve broke. I replaced it and now the washer display comes on lights up but the time display remains dark. When I push the start button nothing happens. the water never starts to flow, the lid does not lock and the cycle does not start.
I was told to replace the control module. I changed it and there was no change. what next? A new washer?
Thanks,
Anne!
Add a comment
1 Answer
Chosen Solution
Is this a 110V wall plug or a 220V? If a 220 V use a multi meter and see if both sides are hot. Also flip the breakers to reset them. Unplug the machine before doing so and leave it unplugged for five minutes.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 92
