My bit is stuck. Help!
I was using it for a while, but when I tried to switch bits, I couldn't - the bit is stuck.
Any tips? Am I doing something wrong?
hold in the blue button near the bit and twist the part that holds the bit clockwise until it kind of locks into place. Then twist counter clockwise while still holding in the blue button and it should come out
Sometimes they get gummed up and stuck in the collet; a little elbow grease and some penetrating oil, along with @glinebaugh's answer above, should do the trick.
Thanks so much!
The saw attachment is all plastic in casted plastic whic covers the collet. I tried to drop oil through the opening but don’t think it reached the collet because no room. The saw is held on by a lid the screws on. Once it is unscrewed still can’t get to the collet
None of the above worked ugggg. You can’t get the wrench to the collet because it is all covered in plastic and the whole saw unit will not budge
My dremel saw unit is stuck on power unit. Can’t get to the shaft to put a wrench on it. The whole saw unit cover to where you need to put the wrench to remove. Pushed the blue button did not budge. Help
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,788
