The DKnight MagicBox II is a small portable Bluetooth speaker with Enhanced Bass and build in Microphone for hand free phone calls.
14 Questions View all
Device won't hold a charge, what do I do?
When the charger is plugged into the device the device works fine but when plugged out it dies shortly after.
1 Comment
Where I can Buy a Battery for a Big Magic Box???
by
Add a comment
1 Answer
Chosen Solution
If the device turns on when the charging cord is plugged in, but immediately shuts off when you disconnect the device. Then, I believe that you may have a faulty battery, since the charging port and cable appear to be working properly. I would recommend looking into replacing your battery.
2 Comments:
If you need more assistance I would recommend checking out the DKnight MagicBox II Troubleshooting Guide
by
I'm having the same issue, and at first glance I can't find an easy way to pop the speaker open. Where are the screws hiding?
by
Add a comment
Add your answer
Bernard Smith will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 2,355
