2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Question Closed
Getting 4SNS/1/C0000008: Ts0P--124 error
hi guys,
My A1342 Macbook 7.1 Unibody (mid 2010) I got this diagnostic error code:
Its probably palm rest temp sensor related. Any idea where it is located / how to fix it?
Thanks in advance
Kris
Add a comment
1 Answer
Most Helpful Answer
Here's a good write up on the error codes: How to invoke and interpret the Apple hardware tests
So if we dissect your error: 4SNS/1/C0000008: T s 0P--124
  • 4SNS - System sensor
  • T - Temperature
  • s - Palm rest
So yes you likely have a palm thermal sensor failure! The cause is likely liquid damage seeping under the trackpad or keyboard. Double check the Trackpad connection on the logic board if that doesn't help. You'll need to replace the trackpad.
Score 2
6 Comments:
Hi Dan, thanks for the info but i've tried 3 different trackpad cables with the same result - error remains still.
by
Not good ;-{ Sounds like you have liquid damage either the keyboard or the logic board will need attention.
by
I've replaced keyboard already (after liquid spill) but for some reason power on button doesn't work and to turn it on (after shutdown) need to short keyboard connector pins on the logic board...is there anything what can i do? for now, using MacFanControl to slow fan down
by
Did you find any spillage on the logic board?
Are you sure you replaced the keyboard with the correct version?
by
well, didn't see anything strange on logic board and keyboard was listed as for this model of Macbook
by
Show 1 more comment
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 1,116
