The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 Questions View all
Question Closed
Why I can't shift
Manual 5 speed shifter
I have a 2004 2.2l, 5 speed manual, I can't shift from first to second and 5th and reverse, I removed the shifter, and there is a square piece with a rod that seems to have detached from somewhere... Does anyone know how to fix it, or change the whole thing.
Tanks
1 Comment
Already saw this picture, my problem it's under the knob, something or part with a square shape attached to a rod, it's a one part piece, seems to be undue from something... Thanks anyways
by
Add a comment
Chosen Solution
Here's a diagram of the parts, see if you can determine what's disconnected or broken or post a picture.
http://www.wholesalegmpartsonline.com/sh...
Here's how to adjust the shift cable: http://www.wholesalegmpartsonline.com/sh...
Score 4
Add a comment
Brandon this is a 2 cable shift link and what has happened is one of your cables is either broke or not adjusted right . look at where the linkage is connected to the gear box and have someone in the car running the shifter through the gears it should be aparent which one needs to be replaced by which one doesnt move. Hope this helps
Score 3
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 698
