Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
During phone calls other person can't hear me
Callers are unable to hear me. I'll bang the phone a couple of times and sometimes the mic works. I don't think the mic is bad, it's the mic connection that is bad.
Vibrate hasn't worked for a year now. Since I had it repaired for broken glass.
Thanks
Score -1
Add a comment
Chosen Solution
your microphone is gone. the fact, that it only works sometimes means, theres no perfect connection there.
you need to follow this guide:
iPhone 3G Dock Connector Replacement
you can see, step 17 is where you take the dock connector out. on that assembly, there is small rubber cap, hidding the actuall mic. instead of changing it, i would rather change the whole assembly. the work is not worth it, there is too many things that can go wrong in case of soldering the mic off and on again...
1 Comment:
here is the whole thing...
by
Add a comment
It's a problem with the Mic connection and not the Mic. When I press the bottom right side of my iPhone, the mic works. So, I opened up the iphone and added a thin layer to keep the mic connection pressed. You can find the connection easily on the bottom right of the iPhone. This solved the problem.
Add a comment
Add your answer
Dan Popela will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 6,619
