A business-class notebook with a 13.3" touchscreen display.
How can I replace my LCD Screen?
My screen recently broke, it refuses to turn on. I read through the tear down and was unable to determine what I should do in order to replace the screen.
Add a comment
1 Answer
Chosen Solution
Hi Mitch,
Try taking a look at the LCD replacement guides for similar models. The HP EliteBook 8440p has a LCD replacement guide and so does the HP EliteBook 6030p. You can also find a replacement part on Amazon. The replacement LCD for your laptop can be found here. Be sure to double check your model numbers to be sure you've ordered the correct part. Good luck!
HP Elitebook 6930p Display Assembly Image
Guide
Removing the HP Elitebook 6930p Display Assembly
Difficulty:
Moderate
45 minutes
HP EliteBook 8440p LCD Image
Guide
HP EliteBook 8440p LCD Replacement
Difficulty:
Easy
20 - 30 minutes
Score 1
Add a comment
Add your answer
Mitch Kev will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 3,036
