A Windows 8 smartphone equipped with a 1 GHz dual-core processor, LCD touchscreen display, 8GB of storage, and a 5MP camera with 720p HD video recording.
6 Questions View all
Can't connect to the internet
I am trying to use the internet browser on my Nokia Lumia 521 but the phone doesn't load any webpages.
Score 1
Add a comment
1 Answer
Chosen Solution
You should first check to see if the Wi-Fi is on. Select Wi-Fi in the settings list and if it is off, drag the switch to the right and it should turn orange. If the Wi-Fi is already on, you should try moving closer to the source in order to obtain a better signal, and if that connection is still not working, you may be connected to the wrong network. Select Wi-Fi under the settings menu, a list of networks should appear, and select the network that you are trying to connect to. I recommend you also look through the troubleshooting guide.
Add a comment
Add your answer
Selamawi Ambaye will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 600
