The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
Samsung S3 ne démarre pas?
Hi my Samsung Galaxy S3 S III SGH-i747M doesn't start anymore?
1 Comment
Have you tried a new known good battery? And charger and cord)(
by
Add a comment
Most Helpful Answer
What happens when you try to turn on the phone? Do you have it stuck at the samsung logo? If yes does it stay there or reboot automatically and show it again?
Try leaving it on charge for half an hour if that does not work you may need to do a factory reset or reload the software on the phone in order to get it working again.
Disclaimer: I am not responsible for any data lost from your device when you follow the steps below:
To factory reset:
Hold power button + volume up + home button until Samsung logo appears. When Samsung logo appears stop holdig the power button but continue holding the other buttons. Once you get into a recovery menu which usually release all keys.
Use volume keys to navigate the menu and the power / home key to select the highlighted option.
Do wipe data / factory reset. Wait for this to complete and reboot phone.
If this still doesn't solve the problem then you will need to restore firmware using Samsung kies.
Score 1
1 Comment:
Thanks i dont see any logo!!!
my phon is break
by
Add a comment
i have the same problem but i can't do this steps beacause it is still restar evrey time !!
Add a comment
Add your answer
Med will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 119
