Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Why won't my phone charge?
I work for a repair shop. After replacing the LCD the phone stopped charging; everything else worked. I replaced the charging port and the battery, but still it will not charge. I've tested the same charging port and battery on other 4s and they will charge, which leads me to think the logic board got damaged during the repair, thoughts?
Score -1
Add a comment
1 Answer
Most Helpful Answer
iPhone 4S is prone to battery connector pry damage. Check it first and report back. You can examine it under the microscope or use a multimeter to check for continuity.
Score 1
Add a comment
Add your answer
Jim will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 72
