Realtek 12S Audio Codec
Dit apparaat geeft bij apparaatbeheer eigenschappen de volgende tekst
Dit apparaat start niet ( code 10 )
Er zijn onvoldoende systeembronnen beschikbaar om de API te voltooien
Oplossing?
Online Translation.
2S Realtek Audio Codec
12S Realtek Audio Codec
This device displays in Device Manager features the following
This device does not start (code 10)
Insufficient system resources exist to complete the API
Solution?
3 Comments
Hoi,
Welke OS is geïnstalleerd op uw laptop ? Heeft u geprobeerd het bijwerken van de drivers voor de audio- apparaat?
Hi,
What OS is installed in your laptop? Have you tried updating the drivers for the audio device?
by jayeff
Hoi Jayeff, Thanks for the answer! Original was W8.1 after free update W10.
After update the battery was no longer charging. After disconnecting the cabel of the battery en reconnecting the cabel problem was solved. I flashed the BIOS to the latest versie also updated all the drivers. Still the problem with the Realtec audio. I had contact with ASUS.nl and the told me to reinstall W10 After that i need again update all the drivers, stay same problem. Now the ask me to carry in the T100TA for the think its a hardware problem and not the software.
Frans
by Frans Verbocht
Hallo Frans ,
Als de audio gewerkt met Win 8.1 het is vreemd om te denken dat het een hardware probleem gewoon door bijwerking te Win10. Kan toeval ik veronderstel zijn.
Hi Frans,
If the audio worked with Win 8.1 it's strange to think that it is a hardware problem just by updating to Win 10. Could be a coincidence I suppose.
by jayeff
