The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 Questions View all
Cracked screen replacement doesn't come with home button
I ordered a screen replacement. The guide doesn't not reference the home button, so one would assume that the new part would have one. It doesn't.
iPad Air Wi-Fi Front Panel Assembly Replacement
It is possible to move the home button to the new part? If so, where is that documentation and why is it not mentioned in the guide above?
Score -1
Add a comment
You must transfer the home button, flex, and bracket over to the new digitizer. I've never seen one come with these items included.
Add a comment
Depending where you buy the screen it may or may not have the home button installed. The screens I purchase come with the home button but I always remove those and transfer the original home button. When I do a iPad repair I always try to move all the original parts that I can in any repair. If your doing this repair make sure to take pictures of the home button ribbon and how it loops around and hooks into the motherboard. If you don't you will forget how that home button cable ran to the motherboard.
Add a comment
Add your answer
damonbrandt will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 75
