The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
Question Closed
Glass replacement (UV plate)
Hello guys, i have a question for you. I need to replace glass on Samsung S III i9300, I replaced many pieces before but in this case I overheated display in fact and I had to detach UV foil. Now I have only silver display under glass and it is wierd. Display and touchscreen is still 100% functional. Is there any plate which I can apply on the display under glass?? THX for every reply.
Add a comment
1 Answer
Most Helpful Answer
You mean you've removed the polarizer? The polarizer is what makes the screen dark.
Here's the order of the display
Display>Polarizer>OCA (or LOCA in your case)> Front Glass
You have removed the polarizer but it is possible to put a new one on although be careful because if you get bubbles it's going to be a pain to get off. I have a polarizer laminator and autoclave so if I get bubbles at all I would just put it in there for 10 mins but I'm usually fine. It is possible to do it by hand as I used to do it.
Score 1
2 Comments:
Thank you for advice, i really apreciate it. Can u tell me how I can detach rest of glue and which glue i need to use for new polarizer? Thank you so much
by
Send me a picture of the display so I can see what exactly is going on. The polarizer has it's own glue, you peel off the film and apply it. Make sure you clean all the residue (if any) from the display
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 75
