Camera is stuck on backward view
My camera is stuck so I only see myself on the screen! Please help
Hi,
You have 2 options:
Flex cable (camera, light sensor, earspeaker) is damaged and you have to replace it, check ifixit.com for spareparts.
Connector is not in possition, you have to fit in the good way.
Regards.
Luis
Thank you. Not convinced but will try your suggestion.
Otherwise you can clean the connectors with a brush, sometimes its just dust, I suspect the phone could be "water damaged", check the upper water sticker.
Good luck! ;)
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 40
