The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 Questions View all
How can I fix my xbox 360 red dot?
My Xbox 360 slim powers on fix, would play for 10 to 15 minutes then green dot would turn red and d screen would go blank, light on the power supply turns from green to orange. When turned off for 2 to 3 hours, turns back on works for 10 to 15 minutes then red dot appears again. Please can someone help me???
Score -1
Add a comment
Chosen Solution
Hi,
Red dot, means "fatal failure", The Xbox is indeed a "PC" inside a "box", If you want to fix that you have to open the machine and clean ALL the ventilation holes, after that change the "cooler heat pasta", because Im almost sure is "DRY", after that you can play 24/7. ;)
Regards.
Luis.
Add a comment
Thanks a lot, am give it a try an see what happens. One last question, which cooler heat pasta would you recommend arctic silva 5 or arctic cooling mx-4
Add a comment
Add your answer
verol fraser will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 296
