Keyboard wont connect to tablet
Keyboard will not work after I connect it to my tablet
The HDMI port must be enabled for the keyboard to work. Go to display and check HDMI.
Thanks, that did the trick!
That worked. Glad to see an expert that actually knows what he's talking about. Thank you!
Thanks for the hdmi info. Learn something new every day:-)
Thank you so much! I've been without a keyboard for over a year now. Rca sent me several replacements; some worked for a short while, some didn't work at all. Your solution did it! You are my hero!
I have the same problems but i went to display and im not seeing anything that says hdmi
you may need to reinstall the drivers or check the docking port to make sure the docks are both clean and have no lint as this has been an issue with this 2 in 1. hope this helps
How do I reinstall the drivers. I bought a different keyboard cause mine quit working, now the new one won't work......Help......
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 13,403
