How to connect to internet through ethernet?
I just newly bought an ASUS K555L with windows 10. Our wifi internet connection is working properly but when i try to connect to internet using an ethernet cable, the laptop can recognize the network but no internet access. How can I fix it?
Score 1
Add a comment
Most Helpful Answer
You can connect Macs and PCs to the Internet in this way, as long as they have Ethernet ports available.
An Ethernet cord can be used to connect a computer to the Internet.
Step 1
Attach one end of an ethernet cable to the ethernet port on the ethernet to USB adapter. An ethernet cable looks like a large telephone line and an ethernet port looks like a telephone jack.
Step 2
Locate the ethernet port on the device that you want to connect to the computer.
Step 3
Insert the other end of the ethernet cable that's attached to the ethernet-to-USB adapter into the ethernet port on the device.
Step 4
Find a USB port on the computer. A USB port is labeled "USB" and it will also have an image that resembles a triton, or a three-pronged spear.
Step 5
Insert the USB end of the ethernet-to-USB adapter into the USB port.
Score 1
Add a comment
Short answer is use the Wi-Fi connection :-)
Long answer:
I've discovered that when I connect to my Internet using two methods, things don't go well. Make sure your choosing ethernet, disconnect from the Wi-Fi network. Mainly because the router is a pending your computer two addresses and he gets all wonky.
Add a comment
Add your answer
Allaine Garcia will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 23
All Time: 1,462
