A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1696 Questions View all
Replacing the optical drive (BDP-015)
Ifixit has listed 3 versions of the daughter board bdp-010, bdp-020, and bdp-025. I have a optical drive with a bdp-015 daughter board on it. I believe the optical drive needs to be replaced. Is this part interchangable? Also I would like to know if the bdp-015 has any pros and cons compared to the others.
Score 1
Add a comment
1 Answer
Chosen Solution
Hey Joel,
Earlier today I had the same issue: had a PS4 with a BDP-015. I was able to replace it with a BDP-010 drive (using their older/existing daughterboard of course). The drive tested fine after the repair.
I figured that the BDP 015 and 010 were probably compatible since it's already established that the 020 and 025 are compatible.
1 Comment:
Thanks for responding Jordan. So I can buy a bdp-010 optical drive as long as it's the appropriate model number? My ps4 is the cuh-1115a version. Also which brand did you go with? Original or aftermarket?
by
Add a comment
Add your answer
Joel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 1,465
