The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
169 Questions View all
How can I remove stripped Torx T2 screw?
I am using Japanese 3G vita (PCH-1100) and I was going to replace the 3G networking card that shipped from Europe. (to elimate SIM Lock.)
but unlike other reigon vita's, mine have a two of Torx T2 screw is tighten in 3G card.
so i bought dirt-cheap T2 screwdriver from local store and this thing stripped the screw :(
how can i take out this stripped T2 screw?
I tried rubber band method / soldering screwdriver to screw / put loctite 401 to screw head and stick screwdriver in to stripped head but none of this trick worked.
can anyone give me a advice ?
p.s: I got a spare screw so I don't bother if screw is destroy during removal.
1 Comment
Drill it then use vise grips, an easy out could work . Depends on how bad it is. Make sure the drill bit you use is of good quality
by
Add a comment
Chosen Solution
Try screw grab I have heard very good positive feed back on using it. Here is a link of the product.
http://m.skygeek.com/screwgrab.html?utm_...
Add a comment
Most Helpful Answer
I solved the problem.
I used PZ-57 Precision Screw Piler to extract those stripped T2 torx screw.
room was enough to fit that Screw Piler.
Score 2
1 Comment:
Thanks for this. I was trying to install a psvsd in mine and quickly learned that T2 screws are the devil.
by
Add a comment
this will depend on you having a Dremel and confidence what you will need to do is using the dremel make a grove for a flat head screw driver
i sugest stopping every few second so you do not over heat anything
1 Comment:
I don't have a dremel right now. I'll try after bought one.
btw, is there a screw extractor for this kind of screw?
because I have to pay nearly 170 dollars for base dremel set.
by
Add a comment
Add your answer
Dosik Ham will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 20
All Time: 2,775
