Repair and disassembly guides for BlackBerry phones.
448 Questions View all
How to repair charger pin on BlackBerry Curve 9360?
Hi,
A friend need to repair the charger pin of a blackberry curve 9360, his battery does not recharge, so i'm trying to help him. I do already check the battery and it's ok, in fact if you move the cable it work (check the cable in other device and it's ok too). The problem: i don't see the model here and i don't know how to teardown it, so, do you know how to disassembly it? and, do you know how can i repair the charger pin?
Thanks for your answer,
JEMP.
Add a comment
1 Answer
Chosen Solution
Hi,
Here are some links that show how to repair the charging port.
This shows how to dis-assemble the phone.
https://www.youtube.com/watch?v=6W9llLlw...
This shows how to replace the charging port. You will need pcb surface mount soldering skills.
https://www.youtube.com/watch?v=tI6_E1-c...
Here is a link for a source for a replacement port. You made be able to find other more preferable sources.
http://www.etradesupply.com/oem-blackber...
Score 2
Add a comment
Add your answer
JEMP will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,000
