A 2.5 gallon, 2HP utility Wet/Dry Vacuum manufactured by ArmorAll.
Why won't my vacuum turn on?
My vacuum is plugged into a working outlet but when I flip the power switch nothing happens.
Score 2
2 Comments
Check vac switch
by
I did, it is not working but I don't know where to buy a replacement switch
by
Add a comment
Chosen Solution
There are a few possibilities as to why the vacuum won't turn on. First, check the cord for damage. Make sure to unplug the vacuum first. If the vacuum continues to not turn on properly, the power switch or the motor may be faulty. Refer to the troubleshooting page for detailed help.
Score 3
Add a comment
Check vac switch. If vac switch the little yellow box on circut pop. Wnt switch on
Add a comment
Add your answer
Abel Manring will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 51
All Time: 9,077
