Why has the sound suddenly stopped?
Hello, I wonder if you have any ideas? Whilst playing my digital radio on full volume, the sound suddenly stopped. Everything else still works: all lights, LCD display, channel selection, tuning, just absolutely no sound. When it happened, the sound was slightly distorted and then just disappeared instantly and has stayed away. The radio is meant to be of reasonable quality and is only about 18 months old. Any pointers would be greatly received. I am however, a complete novice, but happy to start learning and experimenting. If I make things worse then so be it. At least I will have given it a go. Many thanks :)
18 Comments
Bonkers - My revival Bluetune stopped producing sound. Literally ONE STAB of a headphone jack into the headphone socket on the top and it came back to life - BONZA!!!!
by RobbyBobby
Problem: No sound, no display, but red "Mains" light on.
See my solution at http://ahamm.co.uk/roberts-radio-rd-3_FM...
by andychannelify
Exactly the same thing happened to mine. Phoned Roberts tech support; they wanted to charge me £40 to take it away and repair it. Just tried your little trick and it's much improved. The volume was very low on the right channel through the headphones. Probably need to spray some switch cleaner in there. Thanks again!
by Adrian Tyler
I have the same problem; tried the jack stab in both ports many times, to no avail - although the line out works fine. Would rather not have to listen to this radio forever through secondary speakers. Is this an amp issue? (Phoned the Roberts' servicing line but was told that the model is now obsolete so they won't repair it.)
by almondo
almondo - see my blog at: http://ahamm.co.uk/roberts-radio-rd-3_FM...
My problem was the 20mm fuse to the power amplifier.
by andychannelify
Show 13 more comments
