Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 Questions View all
No touch screen, where to look for the problem?
Hi.
I have a waterdamaged Ipad 3 with a complete shattered digitizer. I took the whole Ipad apart and cleaned it first with propanol and then in an ultrasonic cleaner, put the thing back together and replaced the digitizer.
Now everything works (battery, lcd, boot-up) but there is no function on the touchscreen.
I double checked the digitizer screen with another Ipad 3 and it works fine. Also I checked the fit of the flexcable on the two connectors and they seat properly.
Any idea where to look for the defect?
Thank you very much!
Update (02/15/2016)
Could it be that the connectors on the logicboard are defective? Is there any way to check for that?
Score -1
1 Comment:
Add: I do have a multimeter to measure
by
Add a comment
1 Answer
Did you try to restart?
1 Comment:
Yes! Tried that a couple of times. Also I noticed that the clock is not changing. Due to the removal of the board it is reset to jan 1st, 1 oclock, and it jumped to 1:01 and 1:02 - then I left it for a few hours and whenI came back it was 1:00 again
by
Add a comment
Add your answer
Chebno will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 91
